cRio isnt connecting to computer.
Well im first off gonna say this is my first year with first and i am excited and ready. Me and team have a problem, After we have set up the ip adress to connect the cRios module to the computer through a wired connection, we get an error that says it cant connect to the cRios module. We are using a regular ethernet cable connection between the computer and port two on the cRios, and the ip adress we are using is 10.33.10.5 through ipv4. Any help is appreciated.
Thanks Team 3310.
Use port 1 on the cRIO.
Port 2 is on a different network.
Try using port 1. I believe port 2 is different.
Edit: side note- I need to improve my typing speed so that I will be able to reply BEFORE someone else does… Hehe
Ok i will try this afternoon. Thanks!
