cRIO messing up
We have tried imaging our cRIO and it keeps failing.
However it reads that we have the new image on the cRIO.
So we have tired to deploy code onto and it fails to connect to the real time target.
Any help?
Thanks
You need to address the imaging issue first - when new images are released (as they likely will before competition), you’ll need to update to them before you can compete.
Could you give more details about how the imaging process fails?
What programming language are you using?
What is your network configuration?
Make sure that your network settings are set correctly, or else it’s doomed to fail.
