cRIO to cRIO2 Conversions Required?
CD,
I have been programming at home with a 4 slot, cRIO2 and plan on transferring the software to the original 8 slot, cRIO. Are there any special things I need to be made aware of? I searched but couldn’t find any documentation.
I don’t think the application changes any unless you are using non-standard slots. But it uses a different image and when you setup the debugger, it uses a different kernel.
HTH
