Our main early failure points (and solutions) at the Ventura Regional:
Radio disconnects
Problem
At some points during the match, the radio would lose power and immediately reboot
Solution
We connected POE and Barrel jack for redundancy on the radio power. Also we routed the barrel jack and poe to the same vrm
Falcon Manufacturing issue
Problem
During the inspection, we found that our frame was charged. We found after tracing it that a Falcon’s case was receiving charge from the inside. Upon further inspection, a glob of solder was manufactured wrong and was touching the frame.
Solution
We put electrical tape over the part on the inside.
We are and recommend doing checks on all Falcons before a comp.
Keeping redundancy in mind for critical systems.
Buying high-quality ethernet and micro-USB cables. (Nothing else matters if one of these fails)
We are also planning to stop using extremely old electronic parts (mainly cables and connectors)
Another thing that happened was that 2 of our wire connectors came out (Anderson and a Dupont) so we printed Anderson power pole securers and replaced Dupont with xt30u conectors.
That sounds like a significant fault internal to the Falcon. Has your team reached out to Vex regarding the issue? They would want to know. The TalonFX on the back is not supposed to need a team’s inspection and rework.
This is a good and very familiar sounding list. With commodity connectors, particularly with small contact area like micro- and mini- USB, it can help to hot glue connectors in place for competition.
Yep, this is an uncommon but possible manufacturing defect with the Falcon 500. It is more prevalent with older units but possible in newer units as well.
I do want to emphasize however - please DO NOT open the back of the Falcon 500.
There is calibration between the controller and motor that is critical for the Falcon operating correctly. When you open the back of the Falcon this calibration is lost, and operating the Falcon like this will result in (at best) decreased performance or (at worst) damage to the Falcon unit. Because of this opening the back of the Falcon also voids the warranty.
If you have a Falcon with an internal short please contact our support and we’ll be happy to provide troubleshooting and an RMA for a replacement unit.
