Does anyone know if there is any crossover in the cable from the control panel (as in the joystick one) to the robot control panel . Our male male lead got caught on the drive chain, broke then someone threw it away… (its for the 2003 control system if there is any difference)
Cheers in advance
No crossover.
You can actually use a normal cable. The 2003 Control System didn’t need male-male connectors.
Use a gender adaptor to do the job of the tether on the 2004 control system.
It is a straight through cable. The only reason for the male-male-ness was to prevent you from plugging it into things it wasn’t supposed to be plugged into or accidentally confusing it with the program port on the RC or the dashboard port on the OI…
thanks!
