CTRE_CANifier_GetPWMInput.vi not found in the 2020 labview update
after updating to labview 2019 (game tool 2020) and installing phoenix tuner and the new API’s I launched code in robot main and the code ran fine with no errors but when running the driver station I get the error ERROR  7  Call Library Function Node in CTRE_CANifier_GetPWMInput.vi:3940002->Periodic Tasks.vi->Robot Main.viLabVIEW: (Hex 0x7) File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
I updated all of the code and replaced everything with the new API, I also updated the firmware so i’m not sure why I get the error which is only present in the driver station.
See my reply here: Falcon 500 Programming Help
The short version:
Make sure the Phoenix libraries are on the RIO per the documentation here: https://phoenix-documentation.readthedocs.io/en/latest/ch06_PrepRobot.html#labview
