Our team is getting an “Error 1 CTRE CAN Receive TImeout” message in the logs. We are using SparkMax Controllers so this makes no sense. It follows with a frc.robot.Main.main(Main.java:27) message. We have checked our Can Bus, built and deployed code and seem to have no connection issues. We have re-imaged our Rio, checked the Firmware and IDs for the SparkMax’s and everything seems to be correct. Anyone out there with some ideas??? Thanks
Note that the PDP is a CTRE CAN device, as is the PCM if you are using that.
Also, are you using any of: CANIFIER, Pigeon IMU, HERO board, Talon SRX, or Victor SPX?
The only device we are using that you have listed is the Talon SRX and we are currently using them with the PWM inputs.
Here is another log that we are getting during this process…
Robots should not quit, but yours did!
Warning at edu.wpi.first.wpilibj.RobotBase.startRobot(RobotBase.java:274): Robots should not quit, but yours did!
_6Error at edu.wpi.first.wpilibj.RobotBase.startRobot(RobotBase.java:276): The startCompetition() method (or methods called by it) should have handled the exception abov
There should be more to the stack trace.
