Does anyone have a customized dashboard that they would let us use? I really am not sure how to make one or even program using labview. The reason I want one is to have a larger camera display and the other reason is my antivirus mysteriously uninstalled my frc dashboard without permission and I cant find the download for it anywhere, if someone could help me with either issue it would be greatly appreciated
If you want to rebuild the dashboard, even if you don’t customize it, just build your template project from the Getting Started Window in LV. Then you can open the source or open the build spec and build it. After building, you can set the DS dashboard setup to use LabVIEW or move the dashboard to the Program Files location.
Greg McKaskle
