Cutting Constant Force Springs
Any issues about shortening a constant force spring to save a bit of weight?
Thanks,
JMH
From what I have seen they can be a bit dangerous to cut if you don’t clamp them right, the edges will be very sharp and you run the risk of creating cracks/splits in the spring.
We split the end from the hole, and cut a new end and drilled a new hole carefully with a Dremel tool.
Please don’t. In the grand scheme of things it’s only .5lbs of extra weight. It’s really easy for an uncut spring to cut someone, please don’t make a weapon that could remove fingers for slight weight loss.
I would not have a student cut a CF spring or try to handle a cut CF spring. Pretty dangerous stuff.
I have cut very low load (1-3lb) CF springs with tin snips and then filed off the corners, by clamping the spring firmly to a table. It was still a pain. This would be a last resort weight savings for me, would much rather not touch them. Quite frankly I would rather just not counterbalance the elevator at all if that was the last place I could save weight on the entire robot.
This is a “buy the right part” situation imo. CF springs can be scary.
I have seen them cut to width with edm. This seems to work fine.
If you are going to try this anyway I highly recommend practicing on some smaller ones before the actual article. All normal disclaimers about safety, leather gloves, face protection, etc.
If I had an EDM, I would have the resource to buy the right length spring. :slight_smile:
