I have updated the Classmate and PSoC Programmer multiple times. I can see the board in the PSoC programmer but not when I am in the Drivers account. I have programmed the Hex file that the manual said to program. Does anyone know what the problem is?
I had this same problem - it was fixed for me by downloading the mandatory update, (link) and running it twice: the first time, uninstall the Cypress module (be careful about the driver station, though it can be reinstalled), the second time, reinstall everything you removed.
Before you start, make sure that CyMiniProg isn’t running, or something to that effect. It’ll cause errors if it is.
Thanks, It worked.
The reason you can’t do anything in the driver account on the driver station comp. is because it’s the driver account. It’s not made to do anything else but to run the control program to control the robot. You have to be on the developer account to make code changes.
I Have been looking for a while for a similar problem to one of that yours.
Now I have done what you have said to work, but am still not getting any communication with the drivers station. Do you have any solutions or tips to why this may be?
