Cypress Problems
Hello
we are trying to load the firmware on our PSoC3 board and we continue to have this error show we are following what the getting started guide says to do and we continue to have this error occur.
| Programming Terminated
WARNING!—> | Debug mode enabled, this should be turned off from PSoC Creator before production.
ERROR!—> | The hex file was built for silicon revision ES3, but the acquired device is revision **.
| Use PSoC Creator to generate a hex file for the proper device.
please help
Thanks Zack
Team 4150
Sounds like you’re not alone:
http://forums.usfirst.org/showthread.php?t=14007
Thanks for the link however it still show no help?
Also where is the PSoC3 supposed to be connected to the driver station or the robot itself
It normally connects to the Driver Station via USB.
