so i have been fighting the new dlink unit since the beginning of the season. to my knowledge i have it set to the settings that FIRST has told us. however i still cant see the bridge as a wireless network (i am in AP mode as it told me to be) i am still unable to see or connect to the D-Link when it is not hard-wired. any ideas???
I’m curious what part of How to configure your radio, Rev A made you set it to 5ghz. I’m sure FIRST would appreciate the feedback on how to make the document more clear, because they intend you to set it to 2.4ghz for team us as an access point.
i’ve been having troubles with the dlink, when trying to set it up i can get it onto the dlink page and did change the wireless setting
and i also tried changing the network settings but when i tried to save them the computer kicked me off the page and has not let me back on the dlink page
When you change the DLink IP address, your PC will no longer be able to communicate with it. So the Saving settings page will never return,because it’s trying to load the old IP address that doesn’t exist anymore.
In addition, they wouldn’t be able to communicate even at the new DLink IP address, because suddenly your PC and the DLink are on two different incompatible networks.
After you click save settings that change the DLink IP address you need to go change your PC IP address to 10.xx.yy.5 again.
Then browse to the DLink’s new IP address at 10.xx.yy.1
You just have to pick an IP that is not used by another device. A high number practically guarentees there will be no IP conflicts since cRIO uses .2, DriverStation default to .5 etc.
What he said.
Anything .6 and above is free and clear.
No, you’re right. You’d only go back there to make sure you can see it at the new address. It gives you a warm and fuzzy feeling.
There is often some fiddling with straightening out the IP addresses on the Classmate to switch the Driver Station application between the wireless and wired networks. You have to make sure the wired network adaptor IP address is different than the wireless IP address. Only one of them can be .5
And you have to make sure the Driver Station app. doesn’t keep trying to use the old one.
It’s kind of hard to follow the exact steps taken through this thread, but I think after you change the DLINK and COMPUTER IP addressses, you do need to switch the DLINK into AP mode, browse to the DLINK address and change the frequency of the radio to 2.4GHz.
I just noticed that this weekend.
I wonder how it decides to do this?
Maybe if .5 is already taken? Have to experiment if Greg McKaskle doesn’t tell us.
That could cause unusual problems for teams using laptops as competition Driver Stations.
Something to watch out for on practice day.
If the DS is managing the NIC, it will add .5 to the LAN NIC and .9 to the wifi NIC. If you plug into the field, the laptop should use the wired route, but if it were me, I’d turn off wireless anyway.
