Dallas machine shop
At the competition we heard that there will be a machine shop set up. Are there any details as to what tools the machine shop will have? Drill press? Lathe? Saws? ETC…?
NASA’s machine shop has all of the above…But I believe they use them not you. so you kind of drop the parts off?
They did some awesome on-the-spot weld work for us last year.
NASA has a semi-trailer with all the basic machine tools in it (lathe, mill, bandsaw, TIG welder, etc).
As animenerdjohn said, you don’t touch the machines. You drop your parts off with a drawing or sketch of what you need done. They will machine them for you on a first-come first-served basis.
Also keep in mind their limitations…
Our good friends 1296 dropped off a destroyed swerve module one time. NASA told them not to even expect it back the same day.
Id suggest only using them in an emergency - try to do as much as you can on your own.
Oh, and you must supply the raw materials. They don’t have any.
… which they fixed in a few hours - unbelievable skills!
They did do a good job with that.
Do we have to bring our own aluminum stock then?
better to bring your own metal - they may have some small things but in general they do not have stock
HTH
Where can I buy stock then? I know I can get some through our machine shop, but let’s say I have a piece that’s 5"x5"x5" and needs machining.
McMaster-Carr or OnlineMetals.com are two possible places to order almost any kind of stock.
// Is the 5"x5"x5" piece a solid bar? It will probably take hours for the machine shop at a competition to make if there is any significant weight reduction. Generally the competition machine shops only have a manual mill and lathe, along with a variety of other smaller tools like a drill press, band saw, etc.
It was just hypothetical. I just wanted a measure on the abilities of the shop. So maual pieces smaller than probably a 4" cubed inches of volume is the most ideal. Anything else, you would rather bring copies or if this is a newly needed part at competition, make sure you use your engineer brains to make the design smaller with the same functions :]
