Could someone tell me how you set up the dashboard for the axis camera? We didn’t use it when we competed, and I don’t really know how to set it up so that I can get live feed from the axis camera.
Can you elaborate on what problems you’re having after Greg’s response in your previous thread? http://www.chiefdelphi.com/forums/showthread.php?t=76128
I need to check on things. I switched laptops and I’m thinking that it’s confused with the data. I’ll see if it continues after I sort things out.
I’ve decided I’d go back to the other laptop. It’s not worth the time sorting things out even though I could work faster on a different one. Do the dashboard defaults automatically give you live feed, or do you have to tweak things a bit, and if so, how would I go about that?
~CHSboy
The robot template code automatically waits for a TCP session to send data to on a dashboard. When the dashboard connects to the other side, the images will start flowing.
The dashboard has a button on its lower left corner that controls the display. I don’t remember whether it defaults to on or off, but that is all that is required to control it.
Greg McKaskle
