DCMotorSim but from kS, kV, and kA
I’d like to create a DCMotorSim object but all I have are SysID values for a simple motor for kS, kV, and kA. Is there a way to generate a LinearSystemSim using these values that works like DCMotorSim just without the moment of inertia and everything else.
Just to clarify these values were obtained with the mechanism attached to the motor so I’m just factoring all of those into the “motor” sim
Sample Code.
SimMotorSimple.java (1.4 KB)
The model for just K_v and K_a would be \frac{dx}{dt} = \mathbf{A}\mathbf{x} + \mathbf{B}\mathbf{u} where
\mathbf{x} = \begin{bmatrix} \text{position} \\ \text{velocity} \end{bmatrix} \quad \mathbf{u} = \begin{bmatrix} \text{voltage} \end{bmatrix} \\ \mathbf{A} = \begin{bmatrix} 0 & 1 \\ 0 & -\frac{K_v}{K_a} \end{bmatrix} \quad \mathbf{B} = \begin{bmatrix} 0 \\ \frac{1}{K_a} \end{bmatrix}
You can use LinearSystemId.identifyPositionSystem() to make that.
The model including K_s would be \frac{dx}{dt} = \mathbf{A}\mathbf{x} + \mathbf{B}\mathbf{u} + \mathbf{c} where
\mathbf{A} = \begin{bmatrix} 0 & 1 \\ 0 & -\frac{K_v}{K_a} \end{bmatrix} \quad \mathbf{B} = \begin{bmatrix} 0 \\ \frac{1}{K_a} \end{bmatrix} \quad \mathbf{c} = \begin{bmatrix} 0 \\ -\frac{K_s}{K_a}\text{sgn}(v) \end{bmatrix}
That’s an affine system instead of a linear one tho (ignoring the cross-over point for v), so you’d have to add K_s to a custom sim.
I had a thought about that. So basically I would have to construct my own LinearSystemSim class.
Any changes on the Cx + Du side of things in terms of kS?
I’ll work on that. I’ll probably use LinearSystemSim as a template.
Also I’m using Subsystem and CommandScheduler to “run” the motor when I set an input. Any thing I should worry or care about doing that.
Well, it would be an AffineSystemSim class, but yes.
for the sgn(v) component I would assume I would use the current v for the system as I’m inputting voltage.
If I were to expand this to elevators and arms, subtract kG / kA and kG/Ka cos(theta) respectively?
Also do I need to do anything with the offset angle arrived from SysID for arms or is that just what was used internally by SysID
Yes. Simulating that properly is going to be annoying.
Yes.
It’s a measurement offset to make the model work. You can assume users apply that themselves.
I’m also assuming that I’ll have to discretize little c?
In the Discretization class would I have to alter the M and phi values to incorporate little c. If so how would that be accomplished.
Nevermind. I just caught my mistake in thinking. I just now noticed that c is not multiplied by u.
Therefore it shouldn’t have any bearing on the discretization process from my understanding.
Linear system discretization
\mathbf{x}_{k+1} = e^{\mathbf{A}T}\mathbf{x}_k + \mathbf{A}^{-1}(e^{\mathbf{A}T} - \mathbf{I})\mathbf{B}\mathbf{u}_k \\ \mathbf{x}_{k+1} = \mathbf{A}_d\mathbf{x}_k + \mathbf{B}_d\mathbf{u}_k
See appendix D.1 of https://file.tavsys.net/control/controls-engineering-in-frc.pdf for a more complete derivation.
Affine system discretization
\frac{dx}{dt} = \mathbf{A}\mathbf{x} + \mathbf{B}\mathbf{u} + \mathbf{c} \\ \frac{dx}{dt} = \mathbf{A}\mathbf{x} + \mathbf{B}(\mathbf{u} + \mathbf{B}^+\mathbf{c})
\mathbf{x}_{k+1} = e^{\mathbf{A}T}\mathbf{x}_k + \mathbf{A}^{-1}(e^{\mathbf{A}T} - \mathbf{I})\mathbf{B}(\mathbf{u}_k + \mathbf{B}^+\mathbf{c}_k) \\ \mathbf{x}_{k+1} = e^{\mathbf{A}T}\mathbf{x}_k + \mathbf{B}_d(\mathbf{u}_k + \mathbf{B}^+\mathbf{c}_k) \\ \mathbf{x}_{k+1} = \mathbf{A}_d\mathbf{x}_k + \mathbf{B}_d\mathbf{u}_k + \mathbf{B}_d\mathbf{B}^+ \mathbf{c}_k
where \mathbf{B}^+ is the pseudoinverse of \mathbf{B}.
You can discretize A and B like usual, then just use those in the equation above.
Thank you. I guess I was wrong about not needing to discretize little c. One last question (for now :grin:) Is there a pseudoinverse function in the matrix class or elsewhere in the API
It’s more efficient to use a linear system solver than to form the pseudoinverse directly.
I am beginning to suspect you guys have gone a little ways beyond high school math here…
Didn’t see this stuff myself until first year EE grad school.
So using the linear system solver to find the pseudoinverse. “The .solve method” as illustrated in your code snippet. I would use Bd for m_B , what would I use for nextR and m_A?
Like this:
public Matrix<States, 1> calculateX(
    Matrix<States, States> A,
    Matrix<States, Inputs> B,
    Matrix<States, 1> c,
    Matrix<States, 1> x,
    Matrix<Inputs, 1> u,
    double dt) {
    var discABPair = Discretization.discretizeAB(A, B, dt);
    var discA = discABPair.getFirst();
    var discB = discABPair.getSecond();
    return discA.times(x).plus(discB.times(u)).plus(discB.times(B.solve(c)));
Thanks once again. Any way of creating a Matrix<States, N1> set to nothing for testing purposes. I can’t seem to get Matrix.mat to work for this.
Define nothing. Do you mean not assigning an object to it, or initializing it to the zero vector? The no-arg constructor will do the latter.
I got it. Almost done with both an AffineSystem and an AffineSystemSim. I used a Supplier to handle passing in a function like signum
