Give the following a try. I have a more object oriented version but don’t have a robot to test it on so I don’t want to distribute it yet. If it gives you any problems you can’t figure out let me know. I don’t have WindRiver handy to compile it but it should build.
In order to apply a dead band to a given axis you just need to pass the result of get axis method into InputShape. Then use the result that InputShape returns where you were using the get axis methods.
ex.
float x = InputShape(stick->GetX());
#include "WPILib.h"
// Team 1721 mecanum code 2013 By: Zakary Tobine at 2/11/13 10:33am
// Needs to add 2 relays; one for motor for shooter; one for frishbee pusher
const char inputShape[255] = {0,1,3,4,5,6,7,9,10,11,12,13,15,16,17,18,19,21,22,23,24,25,27,28,29,30,31,
33,34,35,36,37,38,40,41,42,43,44,46,47,48,49,50,52,53,54,55,56,58,59,60,61,62,
64,65,66,67,68,70,71,72,73,74,76,77,78,79,80,82,83,84,85,86,88,89,90,91,92,94,
95,96,97,98,100,101,102,103,104,106,107,108,109,110,112,113,114,115,116,117,
118,119,120,121,121,122,123,123,124,124,125,125,125,126,126,126,126,126,127,
127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,127,
128,128,128,128,128,129,129,129,130,130,131,131,132,133,133,134,135,136,
137,138,139,140,141,142,144,145,146,147,148,150,151,152,153,154,156,157,158,
159,160,162,163,164,165,166,168,169,170,171,172,174,175,176,177,178,180,181,
182,183,184,186,187,188,189,190,192,193,194,195,196,198,199,200,201,202,204,
205,206,207,208,210,211,212,213,214,216,217,218,219,220,221,223,224,225,226,
227,229,230,231,232,233,235,236,237,238,239,241,242,243,244,245,247,248,249,
250,251,253,254,255};
float InputShape(float userValue)
int iUserValue;
iUserValue = (int)(userValue * 127);
iUserValue += 127;
iUserValue = inputShape[iUserValue];
userValue = iUserValue - 127;
userValue /= 127;
return userValue;
class RobotDemo : public SimpleRobot
RobotDrive myRobot; // robot drive system
Joystick stick; // only joystick
public:
RobotDemo(void):
myRobot(1, 2, 3, 4), // these must be initialized in the same order
stick(1) // as they are declared above.
stick.SetAxisChannel(Joystick::kTwistAxis, 3);// Add the 3rd axis
myRobot.SetExpiration(0.1);// The time the motors stop moving after a value is sent
void Autonomous(void)
// Commented out till a later date
//myRobot.SetSafetyEnabled(false);
//myRobot.Drive(-0.5, 0.0); // drive forwards half speed
//Wait(2.0); // for 2 seconds
//myRobot.Drive(0.0, 0.0); // stop robot
* Runs the motors with one joystick mecanum.
void OperatorControl(void)
myRobot.SetSafetyEnabled(true);
while (IsOperatorControl())
float y = InputShape(stick->GetY());
float t = InputShape(stick->GetTwist());
myRobot.MecanumDrive_Cartesian(x, y, t);// Mecanum drive single joystick drive
Wait(0.005); // wait for a motor update time
* Runs during test mode
void Test() {
START_ROBOT_CLASS(RobotDemo);
