Hello All!
I encountered a situation at the FiM Howell event I’m not quite sure how to handle in the future.
Note: The following information was told to me by a CSA with supporting evidence in the form of graphs from FMS data, however, I am not a FTA nor do I have all the information available to a FTA so take what explanations I have with a grain of salt.
The problem was, due to WiFi congestion and interference, the field itself was limited to ~20-25mb/s throughput.
This caused a serious issue when multiple teams were nearing the 7mb/s max the field supported.
The issue was that the bandwidth limiting only occurs as you get near that 7mb/s cap, not when the field is running out of potential bandwidth.
So when the field ran out of available bandwidth, the entire field started having massive packet loss (read: >30%) and latencies above 500ms.
Because 3 robots could exceed the bandwidth required to cause this condition, I asked the CSA (this was just before elims) what my alliance could do if we encountered this condition because the opposing alliance had multiple robots nearing the 7mb/s limit.
*(Fortunately this never happened during our matches in eliminations at Howell)
The answer was “probably nothing”.
I am completely fine with that answer for an event. I understand the event staff only have so many options that they can go through and work out while continuing to run the show.
However, an opposing alliance being able to cause our alliance communications issues, with no ability for mitigation, is completely unacceptable going forward.
To be absolutely clear: I have no problem dealing with reduced bandwidth. I understand sometimes wireless communications are limited due to circumstances outside event coordinators control.
How would you guys deal with a situation like this?
I know we had our alliance turn off any camera streams to mitigate possible issues if the opposing alliance had 2 robots with camera streams, and we also asked the opposing alliances to limit themselves to 2 camera streams and explained the issue to them.
