debugging help
so we are unable to debug the software, if we atemptt to it locks up into watchdog and we can use it
If the user watchdog is being used, it stops I/O when not fed for the specified feed period. This includes breakpoints. If you are on blocks and want the motors and I/O to continue running while at a breakpoint, you can disable the user watchdog.
Greg McKaskle
