Every time I run the debugging program it creates what I think is an infinate loop and I have to stop the program
package org.usfirst.frc.team4284.robot;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.buttons.JoystickButton;
import edu.wpi.first.wpilibj.buttons.Button;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
The VM is configured to automatically run this class, and to call the
functions corresponding to each mode, as described in the IterativeRobot
documentation. If you change the name of this class or the package after
creating this project, you must also update the manifest file in the resource
directory.
RobotDrive Drive;
Joystick drivestick;
Joystick xbox;
int autoLoopCounter;/**
- This function is run when the robot is first started up and should be
- used for any initialization code.
public void robotInit() {
Jaguar FL = new Jaguar (1);
Jaguar BL = new Jaguar (2);
Jaguar FR = new Jaguar (3);
Jaguar BR = new Jaguar (4);
Drive = new RobotDrive(FL,BL,FR,BR);
drivestick = new Joystick(0);
- This function is run once each time the robot enters autonomous mode
autoLoopCounter = 0;
- This function is called periodically during autonomous
/*if(autoLoopCounter < 100) //Check if we’ve completed 100 loops (approximately 2 seconds)
Drive.drive(-0.5, 0.0); // drive forwards half speed
autoLoopCounter++;
} else {
Drive.drive(0.0, 0.0); // stop robot
- This function is called once each time the robot enters tele-operated mode
public void teleopInit(){
This function is called periodically during operator control
Drive.arcadeDrive(drivestick);xbox = new Joystick(1);
Button button1 = new JoystickButton(xbox, 1),
button2 = new JoystickButton(xbox, 2),
button3 = new JoystickButton(xbox, 3),
button4 = new JoystickButton(xbox, 4),
button5 = new JoystickButton(xbox, 5),
button6 = new JoystickButton(xbox, 6),
button7 = new JoystickButton(xbox, 7);button1.whenPressed(new ElevatorReverse()); button2.whenPressed(new ElevatorOn()); button3.whenPressed(new ElevatorOff()); button4.whenPressed(new ArmsOut()); button5.whenPressed(new ArmsIn()); button6.whenPressed(new ArmsVerticalIn()); button7.whenPressed(new ArmsVarticalOut());
- This function is called periodically during test mode
public void testPeriodic() {
LiveWindow.run();
