Default Command must require subsytem
I’m having the following exceptions thrown in my command based test bot:
Warning at edu.wpi.first.wpilibj.IterativeRobotBase.printLoopOverrunMessage(IterativeRobotBase.java:276): Loop time of 0.02s overrun
ERROR  1  Unhandled exception: java.lang.IllegalArgumentException: Default commands must require their subsystem!  frc.robot.Robot.teleopInit(Robot.java:97)
Warning at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:291): Robots should not quit, but yours did!
ERROR  1  The startCompetition() method (or methods called by it) should have handled the exception above.  edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:293)
Anyone know how to remedy this?
Can you share the line where you set the default command? You can refer to the WPILIB docs on how to make a command require a subsystem.
yeah sure : )
drivetrain.setDefaultCommand(m_robotContainer.getDefaultDrive());
And now can you share the implementation of the function m_robotContainer.getDefaultDrive()
public Command getDefaultDrive()
    return defaultDrive;
here ya go : ) thank you
Alright, this is going a few layers deeper than I wanted :slight_smile:
Send all of RobotContainer and if defaultDrive is an instance of a custom created Command send the implementation of that command.
sorry about that :slight_smile:
here’s the RobotContainer class:
/* Copyright (c) 2018-2019 FIRST. All Rights Reserved.                        */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
package frc.robot;
import edu.wpi.first.wpilibj.GenericHID;
import edu.wpi.first.wpilibj.XboxController;
import frc.robot.commands.DefaultDrive;
import frc.robot.commands.ExampleCommand;
import frc.robot.subsystems.Drivetrain;
import frc.robot.subsystems.ExampleSubsystem;
import edu.wpi.first.wpilibj2.command.Command;
 * This class is where the bulk of the robot should be declared.  Since Command-based is a
 * "declarative" paradigm, very little robot logic should actually be handled in the {@link Robot}
 * periodic methods (other than the scheduler calls).  Instead, the structure of the robot
 * (including subsystems, commands, and button mappings) should be declared here.
public class RobotContainer {
  // The robot's subsystems and commands are defined here...
  private final ExampleSubsystem m_exampleSubsystem = new ExampleSubsystem();
  private final ExampleCommand m_autoCommand = new ExampleCommand(m_exampleSubsystem);
  private final Drivetrain drivetrain = new Drivetrain();
  private final DefaultDrive defaultDrive = new DefaultDrive(drivetrain);
   * The container for the robot.  Contains subsystems, OI devices, and commands.
  public RobotContainer() {
    // Configure the button bindings
    configureButtonBindings();
   * Use this method to define your button->command mappings.  Buttons can be created by
   * instantiating a {@link GenericHID} or one of its subclasses ({@link
   * edu.wpi.first.wpilibj.Joystick} or {@link XboxController}), and then passing it to a
   * {@link edu.wpi.first.wpilibj2.command.button.JoystickButton}.
  private void configureButtonBindings() {
   * Use this to pass the autonomous command to the main {@link Robot} class.
   * @return the command to run in autonomous
  public Command getAutonomousCommand() {
    // An ExampleCommand will run in autonomous
    return m_autoCommand;
and here’s the DefaultDrive command class:
package frc.robot.commands;
import edu.wpi.first.wpilibj2.command.CommandBase;
public class DefaultDrive extends CommandBase
    @SuppressWarnings({"PMD.UnusedPrivateField", "PMD.SingularField"})
    Joystick stick;
    private Drivetrain drivetrain;
    public DefaultDrive(Drivetrain drivetrain)
        this.stick = new Joystick(0);
        this.drivetrain = drivetrain;
        addRequirements(this.drivetrain);
        SmartDashboard.putString("Requirements", getRequirements().toString());
        SmartDashboard.updateValues();
    @Override
    public void execute()
        drivetrain.arcadeDrive(-stick.getY(), stick.getX());
    @Override
    public boolean isFinished()
        return false;
I’m guessing you created a second instance of the Drivetrain subsystem in Robot.java. You should only have one instance.
I believe that’s not the case, here’s my Robot class
/* Copyright (c) 2017-2019 FIRST. All Rights Reserved.                        */
/* the project.                                                               */
package frc.robot;
import edu.wpi.first.wpilibj.command.Subsystem;
import edu.wpi.first.wpilibj2.command.CommandScheduler;
 * The VM is configured to automatically run this class, and to call the functions corresponding to
 * each mode, as described in the TimedRobot documentation. If you change the name of this class or
 * the package after creating this project, you must also update the build.gradle file in the
 * project.
  private Command m_autonomousCommand;
  private RobotContainer m_robotContainer;
   * This function is run when the robot is first started up and should be used for any
   * initialization code.
  @Override
  public void robotInit() {
    // Instantiate our RobotContainer.  This will perform all our button bindings, and put our
    // autonomous chooser on the dashboard.
    m_robotContainer = new RobotContainer();
   * This function is called every robot packet, no matter the mode. Use this for items like
   * diagnostics that you want ran during disabled, autonomous, teleoperated and test.
   * <p>This runs after the mode specific periodic functions, but before
   * LiveWindow and SmartDashboard integrated updating.
  @Override
  public void robotPeriodic() {
    // Runs the Scheduler.  This is responsible for polling buttons, adding newly-scheduled
    // commands, running already-scheduled commands, removing finished or interrupted commands,
    // and running subsystem periodic() methods.  This must be called from the robot's periodic
    // block in order for anything in the Command-based framework to work.
    CommandScheduler.getInstance().run();
   * This function is called once each time the robot enters Disabled mode.
  @Override
  public void disabledInit() {
  @Override
  public void disabledPeriodic() {
   * This autonomous runs the autonomous command selected by your {@link RobotContainer} class.
  @Override
    m_autonomousCommand = m_robotContainer.getAutonomousCommand();
    // schedule the autonomous command (example)
    if (m_autonomousCommand != null) {
      m_autonomousCommand.schedule();
   * This function is called periodically during autonomous.
  @Override
  @Override
  public void teleopInit() {
    // This makes sure that the autonomous stops running when
    // teleop starts running. If you want the autonomous to
    // continue until interrupted by another command, remove
    // this line or comment it out.
      m_autonomousCommand.cancel();
   * This function is called periodically during operator control.
  @Override
  @Override
  public void testInit() {
    // Cancels all running commands at the start of test mode.
    CommandScheduler.getInstance().cancelAll();
   * This function is called periodically during test mode.
  @Override
  public void testPeriodic() {
In Robot.java robotInit:
In RobotContainer.java:
oh wow, I didn’t even realize! do you have any easy fix for this?
Remove it from Robot.java? You can just set the default command from RobotContainer.
