yes i accsadentaly deleted the default program and the user program can u help me try to get my robot to move a gain because all the robot does is the brecker turns on but the robot does not move on both user and on defalt can u help me:(
now how would i dowload it into the robot?
*Originally posted by Billyp04 *
**now how would i dowload it into the robot? **
If you don’t know how to download, how did you erase the old ones?
Anyway, grab the Stamp editor from InnovationFirst’s website, open the code in it, and choose Run from one of the menus.
how do u fix pmw2
**how do u fix pmw2 **
With pliers.
The questions you’re asking aren’t answerable without context or more information.
Please think through your situation, the circumstances of whatever’s going wrong, and then ask a coherent question.
on my operator interface thr pmw2 lights r on and i of the controleres are not woring and the right side of the robot does not run but whren the servos r swiched the left side wors and the right side does not wor and the light on the robot does not wor. can someone help me i am a programer on my team and the robot just started to do all this?:ahh
Do you see that key next to the “z” on your keyboard. It’s called “shift”. Learn it, love it, use it. I’m happy to help, but it’s difficult if I can’t read what you are asking. Slow down, use some punctuation, and I’m sure somebody can help you.
[edit]
There’s a spell check button right before you post. Try it.
[/edit]
**on my operator interface thr pmw2 lights r on and i of the controleres are not woring and the right side of the robot does not run but whren the servos r swiched the left side wors and the right side does not wor and the light on the robot does not wor. can someone help me i am a programer on my team and the robot just started to do all this?:ahh **
Umm, I can’t really understand you. But try to use the tank drive default code. I think you are using the two joystick drive from what I can understand.
If My robot’s weels on the right side ar movin but the weels on the left don’t work. but when i change the servo plugs the left one wors and the right does not. and the pmw 2 light on the operator interface is on can some one help me.
Try hooking up another joystick to port two and see what happens.
- Ryan
I still don’t really understand what you are trying to say. Please realize that this is not one of those message boards where it is “cool” to leave letters out of words because you are too lazy to type the entire word. It’s actually quite distracting and really turns people off from wanting to help.
Back to your problem: you really need to provide more info. Which default program are you using? Have you tried re-downloading it? If so, did you make any changes? As rwaliany said, it sounds like you’re possibly using the two-joystick drive, in which case the y axis on port 1 controls pwm1 and the y axis on port 2 controls the other motor.
Which joystick are you moving? Are any of the other LEDs on? What happens when you go into user mode? Is there a switch connected to sw2?
Is the “BASIC Run Error” LED on? If so, download the code again off of InnovationFIRST, re-download that into your robot, and see.
on my operator inter face the PMW2 led is lightup. also the right side of the robot does not move but when i swich the two servo connectors arount thr right side of the robot moves but the left side does not. i am using the 2003 first default program both programs r in the robot the user works eveything else runs.can any one help me with this program?
Like I said, try two joysticks. Does anything work that did not before?
Since, I still do not completely follow, try this, if you want me to help.
**on my operator inter face the PMW2 led is lightup. also the right side of the robot does not move but when i swich the two servo connectors arount thr right side of the robot moves but the left side does not. i am using the 2003 first default program both programs r in the robot the user works eveything else runs.can any one help me with this program? **
PLEASE speak english. “r” is not a word, nor is “i” unless it is capitalized. Same with “thr”, “arount”. Beginnings of sentences are capitalized, and periods are required between them. Commas are good, too. If you look through all the other posts/threads on this board, you will find very few that aren’t writen in fairly good english. Please follow their example.
I see no reason to waste my time trying to understand what you are saying; answering a question, on the other hand, is not a waste of my time and I am happy to do.
I was going to offer a possible solution, but after typing a few screens worth of text, I realized that I was just ranting and didn’t know enough about the problem.
Are the motors that are having problems controlled by relays (in which case I may know the solution) or by PWMs (in which case I don’t)? Are you controlling things with the joystick… (err… axis’ axes? axi? How do you pluralize axis anyway?) Anyway, are you controlling (or trying to control) the robot by moving the joystick or using the buttons? What is hooked up to where? How did you re-download the 2.5 code to the RC with a 2.0 editor?
helllllp me please
With what?
If you look through this thread, you’ll notice two types of responses: some that offer suggestions, and others that don’t understand what you are asking. Have you tried all the suggestions rwaliany made?
In either case, you’re going to have to explain your problem (preferably in English) in a way that we can understand. As of right now, I only know that it’s not working and something about PWM2 being broken.
As has been stated, it’s not entirely clear what the problem is, but assuming you are using two joystick tank drive, are the joysticks plugged into port 1 and port 3? I believe those are the ports used in the default code for the left and right drive variables.
