Defining First code?
“Clean: Deleting intermediary and output files.
Clean: Deleted file “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\main.o”.
Clean: Deleted file “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\user_routines_fast.o”.
Clean: Deleted file “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\user_SerialDrv.o”.
Clean: Deleted file “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\ifi_startup.o”.
Clean: Deleted file “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\ifi_utilities.o”.
Clean: Deleted file “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\user_routines.o”.
Clean: Deleted file “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\compressor.o”.
Clean: Deleted file “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\drive .o”.
Clean: Deleted file “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\utilities.o”.
Clean: Done.
Executing: “C:\mcc18\bin\mcc18.exe” -p=18F8722 “main.c” -fo=“main.o” /i"C:\mcc18\h” -D_FRC_BOARD -D_LARGE_CODE -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Executing: “C:\mcc18\bin\mcc18.exe” -p=18F8722 “user_routines_fast.c” -fo=“user_routines_fast.o” /i"C:\mcc18\h" -D_FRC_BOARD -D_LARGE_CODE -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Executing: “C:\mcc18\bin\mcc18.exe” -p=18F8722 “user_SerialDrv.c” -fo=“user_SerialDrv.o” /i"C:\mcc18\h" -D_FRC_BOARD -D_LARGE_CODE -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Executing: “C:\mcc18\bin\mcc18.exe” -p=18F8722 “ifi_startup.c” -fo=“ifi_startup.o” /i"C:\mcc18\h" -D_FRC_BOARD -D_LARGE_CODE -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Executing: “C:\mcc18\bin\mcc18.exe” -p=18F8722 “ifi_utilities.c” -fo=“ifi_utilities.o” /i"C:\mcc18\h" -D_FRC_BOARD -D_LARGE_CODE -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Executing: “C:\mcc18\bin\mcc18.exe” -p=18F8722 “user_routines.c” -fo=“user_routines.o” /i"C:\mcc18\h" -D_FRC_BOARD -D_LARGE_CODE -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Executing: “C:\mcc18\bin\mcc18.exe” -p=18F8722 “compressor.c” -fo=“compressor.o” /i"C:\mcc18\h" -D_FRC_BOARD -D_LARGE_CODE -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Executing: “C:\mcc18\bin\mcc18.exe” -p=18F8722 “drive .c” -fo=“drive .o” /i"C:\mcc18\h" -D_FRC_BOARD -D_LARGE_CODE -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Executing: “C:\mcc18\bin\mcc18.exe” -p=18F8722 “utilities.c” -fo=“utilities.o” /i"C:\mcc18\h" -D_FRC_BOARD -D_LARGE_CODE -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
Executing: “C:\Program Files\Microchip\MPASM Suite\MPLink.exe” /l"C:\mcc18\lib" “18f8722.lkr” “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\main.o” “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\user_routines_fast.o” “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\user_SerialDrv.o” “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\ifi_startup.o” “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\ifi_utilities.o” “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\user_routines.o” “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\compressor.o” “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\drive .o” “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\utilities.o” “C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\FRC_library_8722.lib” /o"base01.cof"
MPLINK 3.94, Linker
Copyright © 2005 Microchip Technology Inc.
Error - could not find definition of symbol ‘Process_Data_From_Master_uP’ in file ‘C:\Users\Mormannoob\Desktop\Robotics\Code\2008\Base01\main.o’.
Errors : 1
BUILD FAILED: Thu Jan 17 17:54:55 2008"
my team is unsure how to fix this error
Try moving the code to a shallower directory.
I’d guess the path is too long, I forget the length exactly, but I recommend stuffing it directly into c:\ and giving it a whirl. The compiler is silly that way. Doesn’t like long paths.
The compiler can take path names up to 64 characters long anything after i believe it truncates.
Yea our mentor pointed that out after he showed up who new it was so simple
