Definition of a Aluminum Sheet
In the rules for the mini-bots it says that Aluminum sheet is allowed. So what is the definition of a Aluminum sheet. 1" thick, 1/2" thick, or 1/4" thick piece of aluminum? Or could we get a 12" x 12" x 12" block of aluminum machine it out and call it a “sheet”? Where does a sheet of aluminum stop being a sheet and becomes a block?
wikipedia is always right…it says up to 1/4 inch
sounds good to me
I don’t believe melting and casting are disallowed by the rules… in previous years we cast and turned wheel hubs, and at least some of the aluminum in those hubs was… in a former life… sheet.
Now, I’d probably get a Q&A ruling on this, as I’d kind of suspect that “sheet” means that it starts as sheet and stays as “sheet”… but it doesn’t say so (yet) as far as I know. I’d also be prepared to document the fact that whatever cast component you make started out as sheet.
Perhaps a better way would be to use a CNC machine to cut thin layers of your project from sheet stock and build up your mechanism layer by layer… you could use aircraft grade adhesives to hold the aluminum together and then go back and do a final machining pass to get everything exactly to size.
Jason
Food for thought: Vex metal was once aluminium sheet. :slight_smile:
There are some very strong automotive (body repair) adhesives too, probably more readily available and less costly as well.
Aircraft grade adhesive is not an allowable material, is it?
I’d say it stops being a sheet when you can no longer bend it with a normal shop setup.
Now your question is what is a “normal shop set up.” Take 148 the past few years. Sheet metal robots, just bent and riveted.
Its right until I change the entry… jk. Thx for the answer i couldn’t find my answer on wiki I guess a search of “sheet” doesn’t cut it I have to search “sheet metal”, who knew?
Generally speaking, I’ve always regarded anything over 1/8" thick as plate. Don’t they also allow any aluminum bar stock though?
I can bend 1/4" relatively easily in my press, I can bend thicker metal too, but not in very useful ways.
Even if wiki is not always right (that was a little joke) I would say 1/8" is definitely sheet metal, and 3/8" is definitely not sheet metal. So it’s somewhere around 1/4" thick that it changes.
ihave always taught the sheet metal was differentiated from plate by having a gauge number. Consulting the engineer’s handbook, go to this link for clarification and documentation:
http://www.engineershandbook.com/Tables/gauge2.htm
Notice the difference between ferrous and non- ferrous metals.:slight_smile: :slight_smile: :slight_smile:
Isn’t it still?
What Vex metal are we talking about here?
Most of the metal in my VEX kits is steel
The FTC metal is aluminum…
Has VEX changed over to aluminum?
I have some VERY expensive aluminum parts that I got a few years ago from VEX that are aluminum… that is the only aluminum I see on the VEX product site. 99.95 for an aluminum chassis kit… Do they have sheet?
just curious
