Hey guys! I am having trouble resolving this error I get whenever I build my code:
Executing task: gradlew build -Dorg.gradle.java.home=“C:\Users\Public\wpilib\2021\jdk” <
FAILURE: Build failed with an exception.
Where:
Build file ‘C:\Users\frcuser\Desktop\YithCP\characterization-project\build.gradle’ line: 59 -
What went wrong:
Could not determine the dependencies of task ‘:jar’.
Could not resolve all files for configuration ‘:runtimeClasspath’.
Could not resolve edu.wpi.first.cscore:cscore-java:2020.+.
Required by:
project : > com.kauailabs.navx.frc:navx-java:3.1.400
Failed to list versions for edu.wpi.first.cscore:cscore-java.
Unable to load Maven meta-data from https://frcmaven.wpi.edu/artifactory/release/edu/wpi/first/cscore/cscore-java/maven-metadata.xml.
Could not HEAD ‘https://frcmaven.wpi.edu/artifactory/release/edu/wpi/first/cscore/cscore-java/maven-metadata.xml’.
Remote host terminated the handshake
Unable to load Maven meta-data from http://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/cscore/cscore-java/maven-metadata.xml.
Could not get resource ‘http://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/cscore/cscore-java/maven-metadata.xml’.
Could not GET ‘https://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/cscore/cscore-java/maven-metadata.xml’.
Unable to load Maven meta-data from https://repo1.maven.org/maven2/edu/wpi/first/cscore/cscore-java/maven-metadata.xml.
Could not get resource ‘https://repo1.maven.org/maven2/edu/wpi/first/cscore/cscore-java/maven-metadata.xml’.
Could not GET ‘https://repo1.maven.org/maven2/edu/wpi/first/cscore/cscore-java/maven-metadata.xml’.
Unable to load Maven meta-data from https://repo.maven.apache.org/maven2/edu/wpi/first/cscore/cscore-java/maven-metadata.xml.
Could not get resource ‘https://repo.maven.apache.org/maven2/edu/wpi/first/cscore/cscore-java/maven-metadata.xml’.
Could not GET ‘https://repo.maven.apache.org/maven2/edu/wpi/first/cscore/cscore-java/maven-metadata.xml’.
Could not resolve edu.wpi.first.cameraserver:cameraserver-java:2020.+.
Required by:
Failed to list versions for edu.wpi.first.cameraserver:cameraserver-java.
Unable to load Maven meta-data from https://frcmaven.wpi.edu/artifactory/release/edu/wpi/first/cameraserver/cameraserver-java/maven-metadata.xml.
Could not HEAD ‘https://frcmaven.wpi.edu/artifactory/release/edu/wpi/first/cameraserver/cameraserver-java/maven-metadata.xml’.
Unable to load Maven meta-data from http://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/cameraserver/cameraserver-java/maven-metadata.xml.
Could not get resource ‘http://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/cameraserver/cameraserver-java/maven-metadata.xml’.
Could not GET ‘https://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/cameraserver/cameraserver-java/maven-metadata.xml’.
Unable to load Maven meta-data from https://repo1.maven.org/maven2/edu/wpi/first/cameraserver/cameraserver-java/maven-metadata.xml.
Could not get resource ‘https://repo1.maven.org/maven2/edu/wpi/first/cameraserver/cameraserver-java/maven-metadata.xml’.
Could not GET ‘https://repo1.maven.org/maven2/edu/wpi/first/cameraserver/cameraserver-java/maven-metadata.xml’.
Unable to load Maven meta-data from https://repo.maven.apache.org/maven2/edu/wpi/first/cameraserver/cameraserver-java/maven-metadata.xml.
Could not get resource ‘https://repo.maven.apache.org/maven2/edu/wpi/first/cameraserver/cameraserver-java/maven-metadata.xml’.
Could not GET ‘https://repo.maven.apache.org/maven2/edu/wpi/first/cameraserver/cameraserver-java/maven-metadata.xml’.
Could not resolve edu.wpi.first.ntcore:ntcore-java:2020.+.
Required by:
Failed to list versions for edu.wpi.first.ntcore:ntcore-java.
Unable to load Maven meta-data from https://frcmaven.wpi.edu/artifactory/release/edu/wpi/first/ntcore/ntcore-java/maven-metadata.xml.
Could not HEAD ‘https://frcmaven.wpi.edu/artifactory/release/edu/wpi/first/ntcore/ntcore-java/maven-metadata.xml’.
Unable to load Maven meta-data from http://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/ntcore/ntcore-java/maven-metadata.xml.
Could not get resource ‘http://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/ntcore/ntcore-java/maven-metadata.xml’.
Could not GET ‘https://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/ntcore/ntcore-java/maven-metadata.xml’.
Unable to load Maven meta-data from https://repo1.maven.org/maven2/edu/wpi/first/ntcore/ntcore-java/maven-metadata.xml.
Could not get resource ‘https://repo1.maven.org/maven2/edu/wpi/first/ntcore/ntcore-java/maven-metadata.xml’.
Could not GET ‘https://repo1.maven.org/maven2/edu/wpi/first/ntcore/ntcore-java/maven-metadata.xml’.
Unable to load Maven meta-data from https://repo.maven.apache.org/maven2/edu/wpi/first/ntcore/ntcore-java/maven-metadata.xml.
Could not get resource ‘https://repo.maven.apache.org/maven2/edu/wpi/first/ntcore/ntcore-java/maven-metadata.xml’.
Could not GET ‘https://repo.maven.apache.org/maven2/edu/wpi/first/ntcore/ntcore-java/maven-metadata.xml’.
Could not resolve edu.wpi.first.wpilibj:wpilibj-java:2020.+.
Required by:
Failed to list versions for edu.wpi.first.wpilibj:wpilibj-java.
Unable to load Maven meta-data from https://frcmaven.wpi.edu/artifactory/release/edu/wpi/first/wpilibj/wpilibj-java/maven-metadata.xml.
Could not HEAD ‘https://frcmaven.wpi.edu/artifactory/release/edu/wpi/first/wpilibj/wpilibj-java/maven-metadata.xml’.
Unable to load Maven meta-data from http://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/wpilibj/wpilibj-java/maven-metadata.xml.
Could not get resource ‘http://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/wpilibj/wpilibj-java/maven-metadata.xml’.
Could not GET ‘https://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/wpilibj/wpilibj-java/maven-metadata.xml’.
Unable to load Maven meta-data from https://repo1.maven.org/maven2/edu/wpi/first/wpilibj/wpilibj-java/maven-metadata.xml.
Could not get resource ‘https://repo1.maven.org/maven2/edu/wpi/first/wpilibj/wpilibj-java/maven-metadata.xml’.
Could not GET ‘https://repo1.maven.org/maven2/edu/wpi/first/wpilibj/wpilibj-java/maven-metadata.xml’.
Unable to load Maven meta-data from https://repo.maven.apache.org/maven2/edu/wpi/first/wpilibj/wpilibj-java/maven-metadata.xml.
Could not get resource ‘https://repo.maven.apache.org/maven2/edu/wpi/first/wpilibj/wpilibj-java/maven-metadata.xml’.
Could not GET ‘https://repo.maven.apache.org/maven2/edu/wpi/first/wpilibj/wpilibj-java/maven-metadata.xml’.
Could not resolve edu.wpi.first.wpiutil:wpiutil-java:2020.+.
Required by:
Failed to list versions for edu.wpi.first.wpiutil:wpiutil-java.
Unable to load Maven meta-data from https://frcmaven.wpi.edu/artifactory/release/edu/wpi/first/wpiutil/wpiutil-java/maven-metadata.xml.
Could not HEAD ‘https://frcmaven.wpi.edu/artifactory/release/edu/wpi/first/wpiutil/wpiutil-java/maven-metadata.xml’.
Unable to load Maven meta-data from http://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/wpiutil/wpiutil-java/maven-metadata.xml.
Could not get resource ‘http://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/wpiutil/wpiutil-java/maven-metadata.xml’.
Could not GET ‘https://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/wpiutil/wpiutil-java/maven-metadata.xml’.
Unable to load Maven meta-data from https://repo1.maven.org/maven2/edu/wpi/first/wpiutil/wpiutil-java/maven-metadata.xml.
Could not get resource ‘https://repo1.maven.org/maven2/edu/wpi/first/wpiutil/wpiutil-java/maven-metadata.xml’.
Could not GET ‘https://repo1.maven.org/maven2/edu/wpi/first/wpiutil/wpiutil-java/maven-metadata.xml’.
Unable to load Maven meta-data from https://repo.maven.apache.org/maven2/edu/wpi/first/wpiutil/wpiutil-java/maven-metadata.xml.
Could not get resource ‘https://repo.maven.apache.org/maven2/edu/wpi/first/wpiutil/wpiutil-java/maven-metadata.xml’.
Could not GET ‘https://repo.maven.apache.org/maven2/edu/wpi/first/wpiutil/wpiutil-java/maven-metadata.xml’.
Could not resolve edu.wpi.first.hal:hal-java:2020.+.
Required by:
Failed to list versions for edu.wpi.first.hal:hal-java.
Unable to load Maven meta-data from https://frcmaven.wpi.edu/artifactory/release/edu/wpi/first/hal/hal-java/maven-metadata.xml.
Could not HEAD ‘https://frcmaven.wpi.edu/artifactory/release/edu/wpi/first/hal/hal-java/maven-metadata.xml’.
Unable to load Maven meta-data from http://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/hal/hal-java/maven-metadata.xml.
Could not get resource ‘http://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/hal/hal-java/maven-metadata.xml’.
Could not GET ‘https://www.revrobotics.com/content/sw/max/sdk/maven/edu/wpi/first/hal/hal-java/maven-metadata.xml’.
Unable to load Maven meta-data from https://repo1.maven.org/maven2/edu/wpi/first/hal/hal-java/maven-metadata.xml.
Could not get resource ‘https://repo1.maven.org/maven2/edu/wpi/first/hal/hal-java/maven-metadata.xml’.
Could not GET ‘https://repo1.maven.org/maven2/edu/wpi/first/hal/hal-java/maven-metadata.xml’.
Unable to load Maven meta-data from https://repo.maven.apache.org/maven2/edu/wpi/first/hal/hal-java/maven-metadata.xml.
Could not get resource ‘https://repo.maven.apache.org/maven2/edu/wpi/first/hal/hal-java/maven-metadata.xml’.
Could not GET ‘https://repo.maven.apache.org/maven2/edu/wpi/first/hal/hal-java/maven-metadata.xml’.
Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output. Run with --scan to get full insights. -
Get more help at https://help.gradle.org
Deprecated Gradle features were used in this build, making it incompatible with Gradle 7.0.
Use ‘–warning-mode all’ to show the individual deprecation warnings.
See https://docs.gradle.org/6.0.1/userguide/command_line_interface.html#sec:command_line_warnings
BUILD FAILED in 6s
The terminal process “cmd.exe /d /c gradlew build -Dorg.gradle.java.home=“C:\Users\Public\wpilib\2021\jdk”” terminated with exit code: 1.
Terminal will be reused by tasks, press any key to close it.
The thing is, is that, I am connected to the internet when I attempt to build the project. The dependencies I have installed are all offline installs. I have tried uninstalling and reinstalling these libraries to no avail. Any help would be appreciated!!! Thanks!!
