I’m learning how to create custom widgets from wpilib. I’ve got a sample widget created in code. The instructions on how to deploy the plugin to the shuffleboard are a bit vague. How do I go about doing this.
What part are you having trouble understanding?
I’m down to compiling the jar file. I’m not sure the folder path the referencing or how to compile the jar file
Using VS code.
Should I make the plugin in a separate project?
