What went wrong:
Could not determine the dependencies of task ‘:jar’.
Could not resolve all files for configuration ‘:runtimeClasspath’.
Could not find com.revrobotics.frc:ColorSensorV3-java:1.0.0.
Searched in the following locations:
- file:/C:/Users/Public/wpilib/2020/maven/com/revrobotics/frc/ColorSensorV3-java/1.0.0/ColorSensorV3-java-1.0.0.pom
- Required by:
project :
Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output. Run with --scan to get full insights.
// Define my targets (RoboRIO) and artifacts (deployable files)
// This is added by GradleRIO’s backing project EmbeddedTools.
deploy {
targets {
roboRIO(“roborio”) {
// Team number is loaded either from the .wpilib/wpilib_preferences.json
// or from command line. If not found an exception will be thrown.
// You can use getTeamOrDefault(team) instead of getTeamNumber if you
// want to store a team number in this file.
team = frc.getTeamNumber()
artifacts {
frcJavaArtifact(‘frcJava’) {
targets << “roborio”
// Debug can be overridden by command line, for use with VSCode
debug = frc.getDebugOrDefault(false)
// Built in artifact to deploy arbitrary files to the roboRIO.
fileTreeArtifact(‘frcStaticFileDeploy’) {
// The directory below is the local directory to deploy
files = fileTree(dir: ‘src/main/deploy’)
// Deploy to RoboRIO target, into /home/lvuser/deploy
directory = ‘/home/lvuser/deploy’
// Set this to true to enable desktop support.
def includeDesktopSupport = false
// Defining my dependencies. In this case, WPILib (+ friends), and vendor libraries.
// Also defines JUnit 4.
dependencies {
implementation wpi.deps.wpilib()
nativeZip wpi.deps.wpilibJni(wpi.platforms.roborio)
nativeDesktopZip wpi.deps.wpilibJni(wpi.platforms.desktop)
implementation wpi.deps.vendor.java()
nativeZip wpi.deps.vendor.jni(wpi.platforms.roborio)
nativeDesktopZip wpi.deps.vendor.jni(wpi.platforms.desktop)
testImplementation 'junit:junit:4.12'
// Enable simulation gui support. Must check the box in vscode to enable support
// upon debugging
simulation wpi.deps.sim.gui(wpi.platforms.desktop, false)
// Setting up my Jar File. In this case, adding all libraries into the main jar (‘fat jar’)
// in order to make them all available at runtime. Also adding the manifest so WPILib
// knows where to look for our Robot Class.
jar {
from { configurations.runtimeClasspath.collect { it.isDirectory() ? it : zipTree(it) } }
manifest edu.wpi.first.gradlerio.GradleRIOPlugin.javaManifest(ROBOT_MAIN_CLASS)
This is the build.gradle code
Are you on a computer with an active internet connection? My understanding is that if you don’t have it in your local maven repository, it’ll search online. Not having an internet connection means it won’t be able to fetch it.
