Can anyone explain why my code will not stop once centerX1 is equal to 237?
package org.usfirst.frc.team1025.robot.commands.Vision;
import org.usfirst.frc.team1025.robot.Robot;
import org.usfirst.frc.team1025.robot.subsystems.ChassisSubsystem;
import org.usfirst.frc.team1025.robot.subsystems.VisionSubsystem;
import edu.wpi.first.wpilibj.command.Command;
@SuppressWarnings(“unused”)
public class VisionAuton extends Command {
double centerX1;
double centerX2;
private boolean isCenter = false;
public VisionAuton() {
// Use requires() here to declare subsystem dependencies
// eg. requires(chassis);
requires(Robot.visionSubsystem);
requires(Robot.chassisSubsystem);
// Called just before this Command runs the first time
protected void initialize() {
// Called repeatedly when this Command is scheduled to run
protected void execute() {
synchronized (Robot.visionSubsystem.imgLock) {
Robot.visionSubsystem.centerX1 = this.centerX1;
Robot.visionSubsystem.centerX2 = this.centerX2;
// double TargetMidpoint = (centerX2 - centerX1) / 2;
// double disp = (TargetMidpoint - Robot.vision.IMG_WIDTH / 2);
@SuppressWarnings("static-access")
double Turn = centerX1 - (Robot.visionSubsystem.IMG_WIDTH / 2);
//+ centerX2 - (Robot.visionSubsystem.IMG_WIDTH / 2);
// double Turn = (centerX2 - centerX1) / 2 - Robot.vision.IMG_WIDTH / 2;
Robot.chassisSubsystem.getRobotDrive().arcadeDrive(-0.6, Turn * 0.005);
// Make this return true when this Command no longer needs to run execute()
public boolean isFinished() {
if(centerX1 == 237.0 + 10){
return isCenter = true;
else if(centerX1 == 237.0 - 10){
else{
return isCenter == false;
// Called once after isFinished returns true
protected void end() {
// Called when another command which requires one or more of the same
// subsystems is scheduled to run
protected void interrupted() {
