Detecting yellow with the REV robotics color sensor
So I have successfully used smart dashboard to put values of red, green, and blue. How would I utilize yellow (as it is a mix of green and blue) so how would I input the value into code to view it on the smart dashboard?
Represent colors using RGB. Then find the RGB of the yellow you want to see.
I recommend looking at REV’s example:
red and green, actually. The yellow wedge should return a lot of light on both the red and green sensors.
