The following information is based on my own observations of the 2007 OI.
The analog joystick inputs are multiplexed at approximately 38Hz (which is the same as the PWM output period) into what appears to be a current sink, set for about 45uA. When 100K Ohms are presented between the +5Aux pin and the analog input, the resulting voltage will be approximately 0.5V.
Although IFI’s documentation states that In the event that an analog value is less than 0.05V, a value of 127 will be generated., in reality that voltage is closer to 0.5V (500mV) than 0.05V (50mV). I measured something closer to 632mV.
When the 100K pot is at one extreme, the voltage at the analog input is obviously equal to the +5VAux voltage, and at the other extreme, will be in the 500-600mV range. For the sake of this discussion, I’ll use round numbers and use 4.5V for the entire input voltage span. Dividing the span by 256 yields approximately 17.6mV per A/D count.
I should add a note at this point that unless you utilize something like an accurate oscilloscope to observe the analog inputs with just a pot connected, you won’t be able to see how IFI’s input circuit works.
Given that the analog input is driving a current sink and digitizing the resulting voltage, supplying the analog input with a voltage is relatively straight forward. The primary consideration is that the voltage source be able to handle the multiplexed current sink load, which should be no problem as long as the output impedance of your circuit is sufficently low.
How low is good enough you ask? If one A/D count is 17.6mV and the current sink is 45uA, then roughly 391 ohms of series resistance between an ideal voltage source and the analog input will result in one A/D count error.
Due to the fact that the +5Aux line is current limited, the other source of potential error comes from any voltage drop introduced by loading this power source. It appears that rather than using the +5Aux line as the upper reference of the A/D conversion, IFI is instead using the voltage from the other side of their current limiting circuit, hence the errors that are introduced when the +5Aux line is externally loaded.
By placing a few different resistive loads on this power output, I noted that the current limit may not strictly be something like a current sense resistor coupled with a high side switch, such as a MOSFET, as the impedance appears to vary slightly. Whatever it may be, I measure an effective resistance of 3 to 4 Ohms across a 10 to 100mA range.
Assuming a series resistance of 4 ohms, an error of a single A/D count would be introduced with about 4.4mA of loading on the +5Aux pin.
Clearly if an external circuit’s current demand can be held to something in the 10-30mA range only a few percent of the overall A/D range is sacrificed.
The other source of “power” available on some of the joystick interfaces, are the eight outputs intended to be used for lighting LED’s.
These outputs are current limited outputs but are NOT based on a 5V supply. The unloaded voltage on these outputs is approximately 2.5V less than the voltage supplied to the OI (as measured from the tether input… I didn’t check the coaxial input, nor the competition port input). That 2.5V difference tracks fairly linearlly as the power applied to the OI is varied.
From a current limiting standpoint, the effective series resistance appears to be on the order of 500 ohms. So if the unloaded voltage were 5V, the short circuit current would indeed be limited to 10mA.
With the RC powered from 12V, the voltage at the OI tether input is about 0.5V less, and the unloaded LED output will be about 9V, and the short circuit current was measured at about 18mA.
IF a custom interface circuit were designed to power itself from the LED outputs, it would of course become dependant on the limitations of the RC programming to keep the interface powered. Multiple outputs could be combined (used diode blocking just to be safe) to increase the available current.
Returning attention to the more practical source of power, the +5V Aux line, one could design a boost supply and then regulate the output back down to +5V in order to drive the analog inputs across their full range… however one still needs to consider the tolerancing of IFI’s reference voltage versus the voltage generated by the switching supply. For a one-of-a-kind design, clearly just providing a trim pot, or hand selecting components, to trim the supply to match an individual OI could work just fine, but on a production basis would not be practical.
The other potentially tempting method of matching the supply to the OI would be to servo the supply to one or more of the switch contact inputs which are internally pulled to 5V. The problem here is that the +5Aux voltage appears as though it may be seperately derived. The one I was working with measured about 50mV higher on the +5Aux power versus any of the other controller inputs or outputs measured on the other OI connectors.
A switching power supply would require some careful design so as not to adversely effect other devices dependant on the +5Aux power, as well as protection from generating voltages high enough to damage other inputs on the OI.
Additions and corrections invited.
