Has anybody found the distance between the Outer Works and the edge of the tower as marked by “x” is in the figure?
https://scontent-lax3-1.xx.fbcdn.net/hphotos-xpt1/t31.0-8/12471545_886073061509341_4736015287532086605_o.jpg
Thanks:cool:
Thanks:cool:
While that value isn’t explicitly given in the manual, its easy to find by subtraction. If you can’t do that math then good luck building a robot.
As best I can tell, it is about 135". I took this based on the line you made and referenced the field at the nearest feature.
OP, Did that help you? Do you need a different measurement?
Look here: https://firstfrc.blob.core.windows.net/frc2016manuals/2016FieldComponents.pdf
for the tower and batter dimensions and then throw in the field element distances and that should get you what you want.
