Hey CD, I was wondering if anyone knows where to commercially buy direct drive adapters for a mini-CIM to 1/2in Hex shaft. We have made some in the past, but it is annoying.
Thank you
Andymark: http://www.andymark.com/8mm-Keyed-Bore-1-2-Inch-Hex-Adapter-p/am-0588.htm
Vex: http://www.vexrobotics.com/217-3255.html
I need this to span about 6 in. Any ideas on how to make that happen?
If you need 6", you might be better off boring into a stock piece
For the 6" span, your best bet would be to either buy an adapter and shaft coupler from Vex, or bore into stock directly and drill and tap a couple of holes for set screws. It’d be pretty difficult to broach something that small.
