Week 2 Summary - Westside
We used the polar storm to get ahead on our CAD work, and we had a CAD meeting on Tuesday (1/16).
Tuesday CAD Meeting
Team 3 was not able to attend
Team 2 did not progress their design as fast as expected. They had several design concepts and geometries but no tangible robot. Their concept consisted of an over bumper intake mixed with an arm to shoot both at the speaker and the amp. This is similar to Unqualified Quokka’s design, but with a separated intake and shooter. However, this created several problems.
- The intake must handoff the note to the shooter
- A shooter + indexing assembly must fit within the robot and be able to both receive from the intake and be lifted for scoring into the amp. This was tough because it needs to be ~16-18” long in order to hold the note.
- A large arm assembly might interfere with a climbing assembly.
They were also utilizing a climber-in-a-box (AndyMark Telescoping Climber) to complete the climb but with no intent of going for the Trap.
Pictures
Onshape Link
Team 1 had a more complete robot with several major systems nearly completely designed. They had an under bumper intake that fed to a static shooter and a diverter to change the launch angle of the note. To score in the amp, they utilized a plate that prevents the note from sliding back out of the amp after it has been shot into it. A winch with tape measures to push up a hook is used for the climber, and the trap will be done using another source-loaded arm that shoots downwards into the trap.
We were quite happy with Team 1’s design despite some concerns:
- The tape measure mechanism was unnecessary since we have enough height to place a hook onto the chain. Team 1 was designing the tape measure system as if it was a cascading elevator system, which it is not.
- The movement of the winch through the middle of the indexer is quite concerning. It is likely to get jammed and may have problems with deployment. With the concerns regarding the winch and the tape measure, we will likely redesign this particular system.
- The accuracy of the diverter mechanism was put into question. These notes are already being compressed into shapes we are unable to fully predict, how consistent will diverting their movement work?
- How consistent is using the “hood” to score in the amp?
- The under bumper intake is a mechanism Disco has little experience with.
- The angle that the note has to move as its being intakes is extremely steep. Will this damage the note?
Overall, we are quite happy with our CAD progress and think that splitting into teams was a very valuable exercise. With Team 1’s trap design, we have more hope of doing the trap than we had before. The next step for the CAD team is to settle on a design. It will be most likely a mix of both concept robots.
Pictures
Onshape Link
Westside Magnet Showcase
Westside High School had a showcase and open house on Thursday (1/18). We took this opportunity to market our team to Freshmen and 8th graders from some of the local middle schools in HISD.
We made a new poster board to use at our booth. It includes a lot of pictures that we can reference while we are talking to people who are interested.
Poster
Additionally, we used a portable monitor to show people the current state of our CAD for this season.
(Pretend Mike Miles is our cad)
Finally, the programming team got our swerve drive moving, so we used that as our main attraction.
Overall, we think it was a great success. Slowed down progress on our robot though.
Saturday Meeting at Lamar + Sunday Online Meeting (1/20-1/21)
During our weekly Saturday meeting, we split up into different groups in order to accomplish several tasks.
CAD
The CAD team focused on completing the base of the robot. We decided on an under the bumper intake and took inspiration from Spectrum and various other teams in order to create our design.
Our design will have a normal square swerve drive that is sized to 24 x 24. An upper skirt made out of 1x1s is a rectangle that will define our frame perimeter, which will be different from the 24 x 24 swerve perimeter in order to accommodate our under-bumper. This rectangle is placed some distance above the drive rails (as of this meeting it is 2” above, but this was changed to 3.5” at a later date). This rectangle is defined as the “Upper Skirt” and will act as both structure and mounting positions for various systems.
We were considering stacking another 2x1 under the drive rails to lower our belly pan and push notes away. Instead of doing that, we are keeping the belly pan attached to the drive rails, and we are adding a skirt made out of polycarb that covers the outside perimeter to stop notes from getting under our robot. These polycarb plates constitute our “Lower Skirt.”
We decided upon an under-bumper intake for our robot after looking at some of spectrum’s designs. However, we had to design the structure of the robot differently because we are using MAXSwerve instead of MK4is. By placing our intake within the bumper, we do not have to worry about deployment and more safety would be afforded to the intake. However, we are still weary of this design because this is the first time Disco has ever done this type of intake.
Another aspect we were considering was reducing the front drive rail to a 1” height instead of 2” by using a 1x1 and stacking a smaller piece of it for the swerve module mounts. However, we found this unnecessary after assessing the height that the note can climb with our intake.
Build/Test
We also tested our intake and shooter. Build Week 2 1/21/24 - YouTube
Refer to Lamar’s Post above for more details
We also started building our competition swerve modules. (I have no pictures of these)
Week 3 recap is OTW
