Distro block, maxi fuse box, and ground stem
That same Distribution block is used in everyday 3 PHASE power applications. It’s not designed to always have the center empty, sorry but why would they design it like that?
It’s rated to handle any and all equal current as the outer lugs.
Allen Bradley’s Mini Power blocks are rated up to 115 AMPS
http://www.ab.com/industrialcontrols/products/terminal_blocks_and_wiring/power_distribution/pdf/powerblocks.pdf
I am just trying to find out where it says we are required to use the ground lug, when in fact the distribution block is the same if not better.
I alerted the engineer I spoke with at FIRST of all the confusion. He agrees that this issue must be addressed. They would rather answer in an official way for all teams to read and indicated that it is FIRST’s intention to address your concerns via the Q&A later this week. I can only tell you that in a previous conversation I was told that the electrical blueprint is the way to wire the robot using the parts or stated equivalents provided in the KOP. I, as all of you, hope that some changes will be made in these rules but at this point the ground stud, the distro block, the four way maxi fuse block are all part of the equation and we are building our robot to those specs.
To Chakorules: If you wired according to your diagram, it seems you have added more return wire than needed. I would have run a #6 from the battery directly to the fuse panel ground stud as in years past.
For everyone: Even though I quote individual paragraphs from time to time, the manual is a complete document and needs to be read and referenced as such. I take the electrical blueprint as the manual and the written doc as a description of additional detail to the blueprint.
[quote=Al Skierkiewicz]
Chris,
In the past we just stacked two eyelet terminals on the same stud to distribute either supply or return leads. We of course insulate with heatshrink the terminals that are used for either.
Dez,
I have to go along with Chris on the distro block, it is designed for three phase power distro and probably (I can’t remember what the label speced) can handle 600 volts block to block without arcing over. I actually like this block for distro and I think many teams will find it very easy to use. It has two failings though, the #6 doesn’t fill up the input side (That is why I fold over a 3/8" of the #6 to fully fill the void.) and a less than prudent electrical person will force the #10 into a hole without fully retracting the locking screw. This will invariably result in a few strands sticking out to get into trouble with it’s neighbors. Other than the weight, I would like to use this in the future.
I have a slightly different question.
Is the distro block required? Or can we use a slightly different (capable of handling larger wire) distro block instead? It isn’t really clear in the rules wether this is illegal or not. (thinking logically, it would be fine as the block we are using has a plastic cover, is larger, and we are running 8 guage wire through it instead of 10)
BUT, we could be totally off base and be required to use the distro block we got in the kit.
Any ideas?
Although there has been changes made recently in electrical rules (i.e. the drop of the ground stud) the distro block is still in the picture for the moment. Keep checking the Q&A and Team updates for the latest.
