When trying to tune one of our talons to a velocity setpoint… it seems the current smooths without any configuration to get to that point already.
Otherwise I would expect the current to be bouncing around trying to find the right setpoint.
Is there some sort of pid loop already enabled on the talon? Without users configuring? Basically I am trying to figure out how I can drive it to a certain velocity the fastest
There is no PID loop running that the user didn’t already configure on a Talon, but it sounds like you have previously configured a ramp on the SRX.
Ensure you call FactoryDefault on the talon before configuring them in code, to make sure they’re all at the same base point.
If you’re still having issues, send a screenshot of a self-test snapshot while the Talon isn’t doing what you expect.
All configs are persistent across power cycles and will remain so until they are configured again. This includes PID, open loop ramping, closed loop ramping, etc. An easy way to determine is if the method includes the word “config” in it (configFactoryDefault, configClosedLoopRamp, config_kP).
FactoryDefault will set all these configs to their default values.
