I have asked around and people usually just say to convert the falcon examples to neo, but everytime I do it, it ends up not working.
Does anyone have Neo MK4i swerve drive code base code?
We are using Neos, PWM Sparkmaxes, Cancoders, and MK4i swerve modules.
A lot of times when the swerve isn’t working right you will want to double check your module IDs for all of your can IDs and your cancoder IDs are all lined up. We had the translation motors on two of our module switched on a demo bot one time and you would tune the swerve offsets and it would work until the optimize function would go to flip one of the modules translation directions and then the swerve would fight itself I am not proud of how long that took to figure out.
I have our own team’s code. If you would like please contact me on Discord and I can send it to you as well as explain how it all works.
My Discord: Rezq#8253
If you don’t want any help from me here is the repository: Files · main · FRC1622 / public / 2022_TGRobot · GitLab
You will have to sort through the code and find what you specifically need for swerve because it has more code than just swerve.
I’m pretty sure the defacto Neo swerve code is 3512’s, which is for regular MK4’s not inverses, but converting the code should be easy. It also is meant for CAN Spark Maxes, but again, that should be fairly easy to convert. Take a peek at Nick’s reply.
SparkMaxes can be controlled in two ways, CAN and PWM. If its a SparkMax on the CAN Bus then you control it using the CANSparkMax class but if it’s being controlled by PWM you control it using the PWMSparkMax class. It depends on how electrical decides to wire your robot although CAN is better since it allows for two way communication instead of just one way (the SparkMax can send data back to the RoboRio).
The picture shows our prototype chassis with 2 - CanSparkmax at each corner mounted on the printable mount.
The green yellow wiring is the canbus. One pair comes into each swerve module and one leaves. The 2 drives and the cancoder are linked right at the module. So wiring is simplified and more information is available in code. Other wiring to module is the 1 power cable for each drive.
General update: Made a lot of headway in development on the repo, so I recently pushed my new changes to the repo (basically switches to onboard PID on the SparkMax to reduce roboRIO usage). I’m also recently found some mechanical issues in one of our swerve modules (most likely cause for our problems at this point) and that a team was able to get our code to work. We’ll (hopefully) do more testing tomorrow.
Update on yesterday (life stuff got into the way, sorry for the late post): Yep, turned out the Xbox controller we were using to drive was doing some weird stuff. Switching to a different controller fixed our issue. We were able to get swerving yesterday with our code.
I’m from team 6081. We’re also using MK4i NEO swerve and this code got our robot running! Thanks a lot! We are having one problem though. The estimated position of the robot will move thousands of meters when the robot barely moves an inch. The individual drive encoders all read correctly, so I’m assuming something is wrong with how it calculates its position. Any ideas?
