We need a very, very long RT25 belt for an elevator project. It needs to be larger than the 216 tooth that rev sells. Does anyone know if something like that exists? Either an alternate vendor or some way to commission it? If it doesn’t we may have to reprint all of our pulleys to use a store bought belt instead.
RT25 is a custom design for REV as far as I’ve seen. You could try and contact them to ask (they did custom widths for the note counters this year), but I suspect you’ll be out of luck.
It’s likely best to go with a more common profile like HTD5. While it sucks right now to need to reprint, it will probably be worth it in the long run going with a more widely available product.
