Does someone knows how to use the encoder of Talon500 in java?
You use Phoenix libraries. The user guide tells to use the same line of code the you would use in a TalonSRX. However the TalonSRX doesn’t have a built in encoder. So how come? Any help?
I’m unfamiliar with TalonFXs, but with TalonSRXs, they have a method called getSelectedSensorPosition(), there’s also a more advanced object with more data that you can use called getSensorCollection().
