Does the new Pneumatics Hub work with the Old PDP?
My team is considering buying the new Pneumatics Hub, but we were concerned about its backwards compatibility with older components.
Yes you can use a mix of components. However, note that R617-A allows only a PCM to be hooked up to the small (Weidmuller) terminals on the PDP. It’s not legal to hook up a Rev PH there, so a Rev PH will have to be wired to a normal PDP output (one of the Wago terminals).
R617 is about the radio power.
R621 tells you how to power the PCM and PCH (among other things). Either way, a 20A breaker with a single pneumatic controller with a compressor, or up to three PCM/PCH with no compressor or non-radio VRMs.
Edit: Oh, that’s legal too! But certainly not recommended if you’re powering the radio there!
My reference to R617 was specifically this statement in R617-A:
With the exception of a single CTR Electronics Pneumatics Control Module (PCM, P/N am-2858), no other electrical load shall be connected to these PDP terminals
R617-A was updated in Team Update 06 to allow a Rev PH be connected in the same way as a PCM.
Looks like someone might be reading my posts :wave:
