Does the robot speed matter for the FRC-Characterization?
Hello all,
I’ve been using the FRC-Characterization and for the default settings of V/s 0.25 V:6, my base runs very slowly and I get:
kS:0.66 kV:1.9 kA:0.4555 r-squared: 0.994 kP:35.2 kD:16.6
I upped the settings to V/s:0.5 and V:9 and I got:
kS:0.632 kV:1.85 kA:0.628 r-squared: 0.998 kP:41.5 kD:20.2
The kS, kV are close but kA is quite off.
Should I run the Characterizor so that my robot is running full speed at the end?
-Jim
It’s hard to say without seeing your diagnostic plots. Could you share those?
I had the two runs backwards for the 0.25V/s I had:
twombat-025-tdp twombat-025-tdp2
for 0.5V/s I had:
twombat-05-tdp twombat-05-tdp2
The specs for the robot are on my page at:
Tyrannosaurus Wombat
Thanks. Those “tails” on the end of your acceleration plots are rather strange, and are probably the culprit (they may be the result of your robot being so light - it is hard to say for sure); that said, the second graph still looks rather acceptable overall, and I’d trust its results (moreover, its measured kA is very close to theoretical).
Thanks,
In thinking about this a thought occurred to me, I’m testing on a concrete floor not carpet. I may try to find a carpeted floor and re-run the test.
-Jim
