Doubts about Gyro Temp
Hi,
I’m a little concerned about my gyro sensor… I’ve never noticed that it works with it’s pic in a ultra-super-high temperature… :ahh:
Does your gyro works in high temperature too? Is it normal?? Or there’s an evil short-circuit that i can’t see??
thanks,
Giovane
How are you determining that your gyro is getting hot?
If you’re using the temperature output, make sure you are converting the output correctly. Room temperature should be ~2.5V, which corresponds to 298 degrees K, or 25 degrees C. A difference of 8.4mV will equal +/- 1 degree K (or C).
