Drill Motor
:ahh: HElp We CAn’T sEeM TO fiND A Way To KeEP OUr MoTORS lock IntO PLaCE
You can’t seem to find a way to make your Caps lock into place either.
try taping them in
HaS N E One fiRgured How To LoCk The MoToR InTo PlaCE
What exactly are you asking? Are you trying to lock it in low or high gear? Is that what you are talking about?
:ahh:RETraCtion------ THE moTor Is ActuAlly SlipPinG OuT OF the BraCkET:D :smiley: :smiley: :smiley:
*Originally posted by Chris Hibner *
**You can’t seem to find a way to make your Caps lock into place either. **
I was going to say something to that effect also.
My God Dush, that’s annoying.
how do you eliminate the problem of the bosch drill motor slipping out of the back of the motor cradle?
on the bakc of the mount, the motor part where the brusjes are, it is not pinching well in the cradle, this causes the motor to silp out…how do you fix?
We never had this problem but we did have a problem with the drill motor being too loose in the cradle. We reorientated it such that the electrical leads are on the top and the bottom if you lie the unit flat on a table. This helped to wedge it in there. Also make sure that you securely fasten the rings that fit over the top of the unit. This should prevent accidental loss of any drill motors.
