what is the rpm of the drill motors in low gear/high gears exactly through the drill gearing?
In the back of your “Zone Zeal” rule book there is a page that shows the ratings of all the motors.
Wayne Doenges
Hmmmm…
The drill motors run at 20023 RPMs idle. The high gear is 20:1 and the low gear is 60:1. So it should run at 1000 and 300 RPMs respectively. However, this is impossible because it would not free spin with the gearbox on. But you need to check the RPM to Torque chart to see the speed output at the torque output you want.
I think the drill gearbox outputs are 400 and 800 RPM I think. That is what it says on ther drill case ( I think ).
Mike
