I’m trying to image my Roborio 1.0 to the 2025 beta image. I’ve connected the Roborio via USB, and the Driver Station can detect the robot. However, the Imaging Tool keeps saying “no targets found.” I’ve clicked the Rescan button multiple times, but nothing has changed.
Given that the robot IP and Laptop IP are in completely different ranges, and the robot IP matches the USB connection, I’m assuming you have wifi enabled. Be sure to disable other network connections.
Also, disable windows firewall and any other 3rd party firewall/antivirus software you may have running as these can interfere with the connection.
Your ethernet IP is still showing a different range, so some other network connection is configured. Simply turning off wifi in that popup menu often isn’t enough. Having things like Docker or a VPN client enstalled will often add extra network connections.
Please open the network interface settings (Win+R → ncpa.cpl) and disable everything except your USB ethernet connection. If you’re not sure which it is, it should disappear when you disconnect the cable (and should be labeled with NI).
You can re-enable these after the connection is made.
