Hi, my driver station doesnt recognize kinect
i’ve already installed the kinect SDK and kinect server
i tried to run the Kinect Server Debug Mode and it didnt work, and in the skeleton viewer in the Kinect from microsoft program recognized everything of the human player!
Make sure that you have the Beta2 version of the SDK. You can check by going to “C:\Program Files\Microsoft SDKs\Kinect”. The folder inside should be called “v1.0 Beta2”
Kinect on Driver station used to say kinect timeout, but I went into the text file and double checked it and now it says no kinect on the dashboard. I also checked the file locations and those are right as well.
As for the kinect server debug mode, it runs a small window that does nothing and presents nothing but the name in the top right of the window as (2012 FRC Kinect Server) then it does nothing. I just restarted my computer with the kinect in it and it still says no kinect on the DS but it still works in the kinect skeleton viewer sample or whatever it’s called.
Be sure you are using the proper version of the Kinect Beta2 SDK. I was trying to install the 32-bit version of the SDK on a 64-bit computer and had the same issue.
If you don’t know which SDK you have/need, download both the 32-bit (x86) and the 64-bit (x64) versions and try them one at a time.
A timeout string means that the Kinect Server SW isn’t running, and you may want to click the restart button near the LED.
If the string says No Kinect, that means the server is running, but that the server cannot open a connection to a Kinect device.
Especially if you are on a slow computer, you may want to disconnect, reboot, connect, and listen to the sounds and watch that the “drivers being installed” stuff comes up in the bottom right. You could also check the Device Manager and verify that the drivers successfully loaded.
Some MS guidelines are to plug the Kinect into its own USB controller, and especially don’t plug it into a hub with lots of other devices.
What restart button? If it’s on the drivers station, I’ve tried that and it doesn’t connect. It flashes red quick then goes to the no kinect grey. Which leads me to think it’s an Frc kinect Server.
I have tried taking everything off other than the kinect and no luck. I know the pc cannot connect two programs to the kinect so ive been avoiding that as well. It will run the skeleton viewer. (not the -wpf one what does that mean? It says I can connect another kinect) it just will not connect to the diver station. And after up to 3am of work, windows is driving me crazy. I might smash this piece of crap >.<
If you want to debug this, you can load the source for the Kinect Server and run it in Visual Studio Express to see if the errors returned by the NUI calls help. I’d gladly tell you how to fix it, but I haven’t seen this before.
Other swap-out things you can try are to try a different account, a different computer, or a different Kinect.
I’m going to try throwing all the kinect files on the netbook we got at kickoff and see. The only problem with the netbook is that it didn’t update labview correctly, so I have one pc that has labview and can’t debug the kinect diver station and one that might run the kinectdriver station and not labview…
the netbook or whatever failed as well but thats because it didn’t recognize direct x runtime, WHICH I HAVE! >.< so I’m back to my acer i3 to solve the problems. I currently am downloading the c sharp express, BUT I have version 2010 before and I’m trying 2008 to see if this may be due to an incompatibility issue.
rererererererrerererererererererre installing kinect SDK. hopefully for anyone else having these issues, I’ll have it solved, if not, please post how you fixed it or how you went through the instructions because i’ve noticed that those are slightly off as well (for example, the kinect sdk link takes you to a VERY general starter page)
