I am having problems with the driver station installer. I have several laptops and two PSOC boards. On my personal laptop I use PSOC Creator and PSOC programmer. Installing the Driver station kills the comunication to the PSOC devices to both of these applications and the driver station can not access the PSOCs. If I reinstall the non First PSOC software I can program the PSOCs with the first hex file.
I also have a team laptop it only has the Driver staion software and not the PSOC programming apps. It can access both PSOC devices from the driver station.
We have a Classmate PC that has been flashed with the new image file (Win 7 and driver station 01/05/11. I’m not sure if it has only the driver station or if it also has the PSOC programming package. It can access one of our PSOC devices and not the other. I have tried reflashing the one that it can’t read several time and also tried flashing some of the sample apps onto it. It seems to be working correctly.
Anyone have any ideas or does anyone have both the driver station and the PSOC programming suite installed and working together on the same PC. If you have the later which versions are you running ?
Thanks
Jim
Team 1983
