I’d like to copy the Driver Station Logs to another PC/memory device for deeper analysis while not tying up the Driver Station. Where are the 2019 logs stored on the PC?
Thanks
Thanks
C:\Users\Public\Documents\FRC\Log Files
Excellent! Thanks.
Do you know if I can get away with just copying the Driver Station Viewer folder to the new PC, or will I need to do a full installation of the Driver Station?
I assume you need the LabVIEW runtime, so the easiest way to install that is the NI FRC update.
