one or two drivers of the bot this year
every year for the past 4 years we have had two drivers but this year some seniors want to just have one driver for both buttons and stick
what is your team doing?
It depends on the robot.
If your robot doesn’t have any arms or lifts, or manipulators, it may be better to have only one driver. This way they have control of everything they need to do.
If you have something other than a basic drive platform, and your robot has too many functions for one person, then you should use 2 drivers.
Basically, if one person can handle the whole robot well, then you can use one driver.
only bad thing about one driver what if that person freezes on the field know one else can touch the controls
~julie
That’s why you have driver tryouts. To pick the best driver.
Also, please use punctuation.
Not quite true. You can have two drivers on the field, even if only one is required to run the robot. If you can get away with one driver operating all the functions of the bot, I would highly encourage you use the second driver position as an additional coach. Having another set of eyes on the team that doesn’t have to worry about the 'bot every second is another set of eyes that may see the golden opportunity. Both drivers can ‘tag team’ the controls if you wish, switching positions.
This is fairly critical this year, as the human player is isolated from the rest of the team, and won’t be able to communicate effectively. The load on the coach has gone up because of this.
But, I do caution against putting all the bot functions on one person. accurately moving a robot on a small field crowded with 5 other robots, goals and tetras is challenging. If the driver then also has to keep track of a box of switches, things can get pretty complicated fast. It has been done, but I think that when it works is a combination of good controls, simple bot functions and a superb driver.
-Andy A.
this years drivers are going have to very good at talking and listen
I think its better to have two drivers for a few reasons:
In past years we have one driver directing the chassis and another driver controlling all the accessories. The same will probably hold true for this year
If you have any sort of endefector… you almost always have to have 2 drivers. The base driver must be solely concentrated on moving your bot by the other 5 bots and 9 goals on the field.
I also dislike the idea of two coaches. One coach is the brain of the team. He communicates with the other 2 coaches and his 2 drivers. The only thing another coach would do is cause confusion IMHO. If a only a single driver is required, have the second person available shout out time intervals… or interpret the coaches directions to the driver. 2 thinking decision making coaches is bad. The strategy must come from one source period.I am not saying that a second person couldn’t be used… timing and robot alerts are great uses. But it is much much much easier when there are 2 drivers for a robot that has a manipulator of any kind. The drivers are just the hands on the floor implementing what the coach says.
If you don’t have an arm, you can still use the operator as a second coach. The operator could be the person talking to the human player or keeping an extra eye on the field. Even if you don’t plan on using the operator to actually operate, you can still use them for other reasons.
GO 1403!!!
In 2003, we only had one driver, and look where it got us, National Finals. It really depends on the robot and the driver though. If you have new driver/not to great a driver, it is obviously best to have two drivers out on the field. But in 2003, we had a 3 year driver out there doing the rounds by himself, flawlessy might i add.
A few things i can think of for not having 2 drivers:
I know however, all my points can be countered, so it really just depends on the strength of the driver and the strength/diffuculty of the bot.
BTW-I personally think having 2 coaches can be very beneficial this year. You can have one talk to each alliance partner, and each can be watching separate tasks.
As always…45 will have one driver and one operator. Both of the positions are still unfilled at this time since we haven’t had try outs yet. What other team(s) have driver/operator tryouts?
Last year was our rookie year, and before we even started on the bot, we had a student who decided to bring in his RC cars.
It was pretty clear who the best driver was going to be. Every once and a while other people drive it, but he is our main (and only) competition driver.
He’s very good with using controls, and it is better for him personally to have them at the same time, but it all depends on the team. In our team, I don’t think people communicate well, and it’d be hard for more than one driver to control, or even to switch coaches from match to match.
Yeah! on the coaches thing they cant work together in one mind set.
I disagree. If you split responsibilities you can definitely work together. Playing the game should be one coach’s job. Maybe something like watching the time. In this years game you could probably use another coach for watching the goals capped and stuff? If you work it out right you can do well. That’s a guarantee. It worked well for us in 2003. We were the CMP finalist.
We are actually going to have two joysticks for tank steering and use the buttons to move the arm up and down. It’s going to be real simple and we’re only going to have one driver, but a 2nd back up driver to take his place in case if he screws up.
Don’t do it. If you have an arm… use 2 drivers. Don’t say “if he screws up” either. This is supposed to be a fun thing… competitive yes, but fun. You don’t want to swap drivers out in the middle of a match ever. If you split the driving up into two drivers they will do soo much better. I don’t know how to say this other than the drivers are “dumb”…they have NO idea what is going on on the floor. They are concerned with the robot they are driving. The less thinking required to operate a task, such as cap a tetra, the less time it takes to do it. Two drivers is the way to go with a robot that has a manipulator that is used a lot.
We have driver tryouts, also. We have a few practices during the week, with last year’s robot. Interested drivers get a chance to drive and are evaluated over a period of time. We’ll set up different scenarios and courses for them to complete.
Alright ya thanks for the advice. I’ll try to bring that up at our next team meeting.
More then likely we are gonna have two drivers, one to operate the robot and one to operate the grabber arm. We had the same set up last year with two drivers, makes it alot less confusing.
