DriverstationLCD
What all happened to the diverstationLCD. :confused: What did it get replaced by?
Its function is taken over by Smart Dashboard variables and the Basic tab on the Dashboard.
http://wpilib.screenstepslive.com/s/4485/m/13809/l/292213-c-java-porting-guide-2014-to-2015#DSUserMessages::DriverStationLCD
Alan is spot-on with his response that the DriverStationLCD has been removed in favor of instead using the SmartDashboard.
As a beta test team, we implemented a temporary workaround during the beta testing by updating the old control system’s DriverStationLCD class, as it was far easier to port our 2014 robot code (which made heavy use of DriverStationLCD) to the new control system without having to convert all of our DriverStationLCD usage to SmartDashboard. However, our code won’t be particularly helpful to you directly, as we are using Java. What more, we never intended for our implementation of DriverStationLCD.java to be anything other than a short-term temporary solution (for the 2015 robot, we are using the SmartDashboard exclusively), so it doesn’t worry about being efficient – rather, it is actually quite inefficient, printing out the buffers one character at a time. Yet, just in case it is of help to you or other teams, I have attached our “DriverStationLCD.java” that we used during beta testing. I should also add the disclaimer that I haven’t tried this “DriverStationLCD.java” with the 2015 release, so it is possible (although unlikely) that something changed that makes it no longer work.
Also, during the beta testing, team 1511, which was using C++ had shared their DriverStationLCD.cpp and DriverStationLCD.h with us – Jeff Downs of 1511 previously posted a link to their code here: http://www.chiefdelphi.com/forums/showpost.php?p=1422467&postcount=5
/* Copyright (c) FIRST 2008-2012. All Rights Reserved.                        */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
package org.mayheminc.util;
import edu.wpi.first.wpilibj.SensorBase;
import edu.wpi.first.wpilibj.communication.FRCControl;
import edu.wpi.first.wpilibj.communication.UsageReporting;
import edu.wpi.first.wpilibj.parsing.IInputOutput;
 * Provide access to "LCD" on the Driver Station.
 * This is the Messages box on the DS Operation tab.
 * Buffer the printed data locally and then send it
 * when UpdateLCD is called.
public class DriverStationLCD extends SensorBase {
    private static DriverStationLCD m_instance;
     * Driver station timeout in milliseconds
    public static final int kSyncTimeout_ms = 20;
     * Command to display text
    public static final int kFullDisplayTextCommand = 0x9FFF;
     * Maximum line length for Driver Station display
    public static final int kLineLength = 21;
     * Total number of lines available
    public static final int kNumLines = 10;
     * Total number of characters needed for all lines
    public static final int kTextBuffer = kNumLines * kLineLength;
    public static final String LINE_KEYS] = {
    	"String 0", 	//"DB/String 0",
    	"String 1",		//"DB/String 1",
    	"String 2",		//"DB/String 2",
    	"String 3",    	//"DB/String 3",
    	"String 4", 	//"DB/String 4",
    	"String 5", 	//"DB/String 5",
    	"String 6", 	//"DB/String 6",
    	"String 7", 	//"DB/String 7",
    	"String 8", 	//"DB/String 8",
    	"String 9" 		//"DB/String 9",
     * The line number on the Driver Station LCD
    public static class Line {
         * The integer value representing this enumeration
        public final int value;
        static final int kUser1_val = 0;
        static final int kUser2_val = 1;
        static final int kUser3_val = 2;
        static final int kUser4_val = 3;
        static final int kUser5_val = 4;
        static final int kUser6_val = 5;
        static final int kUser7_val = 6;
        static final int kUser8_val = 7;
        static final int kUser9_val = 8;
        static final int kUser10_val = 9;
         * Lines on the left side of default dashboard
        public static final Line kUser1 = new Line(kUser1_val);
        public static final Line kUser2 = new Line(kUser2_val);
        public static final Line kUser3 = new Line(kUser3_val);
        public static final Line kUser4 = new Line(kUser4_val);
        public static final Line kUser5 = new Line(kUser5_val);
         * Lines on right side of default dashboard
        public static final Line kUser6 = new Line(kUser6_val);
        public static final Line kUser7 = new Line(kUser7_val);
        public static final Line kUser8 = new Line(kUser8_val);
        public static final Line kUser9 = new Line(kUser9_val);
        public static final Line kUser10 = new Line(kUser10_val);
        private Line(int value) {
            this.value = value;
    StringBuffer] m_textBuffer = new StringBuffer[kNumLines];
     * Get an instance of the DriverStationLCD
     * @return an instance of the DriverStationLCD
    public static synchronized DriverStationLCD getInstance() {
        if (m_instance == null)
            m_instance = new DriverStationLCD();
        return m_instance;
     * DriverStationLCD constructor.
     * This is only called once the first time GetInstance() is called
    private DriverStationLCD() {
        for (int i=0; i < kNumLines; i++) {
        	m_textBuffer* = new StringBuffer("                      ");
     * Send the text data to the Driver Station.
    public synchronized void updateLCD() {
    	for (int i = 0; i < kNumLines; ++i) {
			SmartDashboard.putString( LINE_KEYS*, m_textBuffer*.toString());
     * Print formatted text to the Driver Station LCD text buffer.
     * Use UpdateLCD() periodically to actually send the test to the Driver Station.
     * @param line The line on the LCD to print to.
     * @param startingColumn The column to start printing to.  This is a 1-based number.
     * @param text the text to print
    public void println(Line line, int startingColumn, String text) {
        int start = startingColumn - 1;
        int maxLength = kLineLength - start;
        if (startingColumn < 1 || startingColumn > kLineLength) {
            throw new IndexOutOfBoundsException("Column must be between 1 and " + kLineLength + ", inclusive");
        int length = text.length();
        int finalLength = (length < maxLength ? length : maxLength);
        synchronized (this) {
            for (int i = 0; i < finalLength; i++) {
                m_textBuffer[line.value].setCharAt((i + start), text.charAt(i));
    public void println(Line line, int startingColumn, StringBuffer text) {
     * Clear User Messages box on DS Operations Tab
     * This method will clear all text currently displayed in the message box
    public void clear() {
            	for (int j=0; j < kLineLength; j++) {
            		m_textBuffer*.setCharAt(j, ' ');
        updateLCD();
