In 4.2 Scoring (pg 37) the manual says:
The SWITCH located closest to its ALLIANCE STATION is considered that ALLIANCE’S SWITCH. While any ROBOT can place POWER CUBES on the PLATES of either SWITCH, an ALLIANCE can only have OWNERSHIP of, and accumulate points for, their SWITCH.
To me this strongly implies that your alliance can only get points from your alliance’s switch. I’m a little more unsure of whether force applies to both switches or just or own.
Also the definition of FORCE in the glossary is:
FORCE
A POWER UP which earns OWNERSHIP points from an ALLIANCE’S SWITCH, SCALE, or both regardless of PLATE position
Since you’re confused and seem to know this might be an issue, I’m wondering if you have other evidence that you might be able to score points for your opponents switch?
