Eclipse C++ not working and PATH error
I decided to go ahead and start the robot coding in C++.
I now notice two things, nothing is working and many things, including stuff in files already made are saying “___ could not be resolved”
By __ I mean type, symbol etc…
I also noticed that when I build, I get this message:
Cannot run program “arm-frc-linux-gnueabi-g++”: Launching failed
Error: Program “arm-frc-linux-gnueabi-g++” not found in PATH
I have dealt with PATH problems before but I can’t find any file or folder like this and I feel like this may be the cause of my problems.
Please Help! Thanks!
Have you installed the C++ toolchains and set up Eclipse following the directions on ScreenSteps (http://wpilib.screenstepslive.com/s/currentCS/m/cpp/l/145002-installing-eclipse-c-java#installing_the_c_toolchains_c_teams_only)?
Yea I have, I’ll try uninstalling and installing eclipse again though
Yea that didn’t do anything…
Did the messages that said things like:
Cannot run program "arm-frc-linux-gnueabi-g++": Launching failed
Error: Program "arm-frc-linux-gnueabi-g++" not found in PATH
go away after you reinstalled the toolchains?
Could you try running this command to see if the compilers are on the PATH:
arm-frc-linux-gnueabi-g++ --version
You should see something like this:
arm-frc-linux-gnueabi-g++ (GCC for FRC) 5.5.0
Copyright (C) 2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Hi, which files is/are the toolchain? I don’t want to delete something I shouldn’t since I have a bunch of FRC-related files
Hey,
For my team we had a similar issue. The way we fixed it is by adding all the bins under C:/frc, I think there are two, to the system environment path. Obviously it’s preferable to put it in a script and not permanently change your path, but it’ll work fine that way. That’s where arm-… is.
Do you know if this will fix the errors I mentioned. Multiple things are highlighted red and say “not defined or found”(etc)
I tried adding the bins but that did nothing…
